RBD Point Object to inherit point velocity.
hopbin9
Hi,
I'm using the RBD Point Object to create a bunch of spheres, but I've set the creation frame for 250. The spheres are instanced on some geometry that is animated, and I want them to inherit the velocity of those points. Right now they just birth with no velocity.
Is this possible?
Thanks,
  On 11/24/2010 at 7:13 PM, hopbin9 said:
Hi,
Is this possible?
Thanks,
yes, you need to create velocity attribute on the points. if you look in the help it's well explained.
