arccos in VOPSOPs
Symbolic
I have a final value at the end of my network in VOPSOPs and it is 0.468. I need to run x=arccos(0.468) in order to find the x as degrees. I know it is 62.1 degrees. Because I used python after my VOPSOP to calculate with some "math.arccos(0.468) - > degrees" stuff.
But how to do that in VOPSOP?
The "Trigonometrical Function" has an ARCCOS in it but the VOP accepts only radians? This might be stupid, but I could not do it?
Any ideas?
Thanks.
(P.S: I am trying to find the angle between two vectors and I know how to do it with the "normalise -> dot -> trigonometric function -> degrees" way, however I am trying another formula.)
Hello Graham,
Thanks.
To actually use the "Trigonometric Functions" VOP, one needs to feed radians into it. But then obviously the result needs to be converted from radians to degrees. Which I was already doing in another branch... anyway it is working now, it was just some parameter export mistake I have made.
Cheers.
