redpaw Posted January 21, 2011 Share Posted January 21, 2011 I would like to use a simple sop solver setup to scale the pieces of a fracture object when they register an impact right now I'm trying to create an impact group with dopnumrecords(".", $OBJNAME", "Impacts", "Impacts")>=1 to activate the group and then pipe that into a multi solver with a sop solver that scales down everyting in the group "impact" but it doesent seem to work, the same setup works if I set it up with a single RBD object, and dopnumrecords(".", "realNameOfsingleRBDobject", "Impacts", "Impacts")>=1 but it seems to have to be different with a fracture/glue object and / or using $OBJNAME instead of the real string name of the object any help would be greatly appreciated thanks -johnc Quote Link to comment Share on other sites More sharing options...
seth_ro18 Posted January 21, 2011 Share Posted January 21, 2011 That should do the trick. The only thing I see is a small typo in your expression. Should be: dopnumrecords(".", $OBJNAME, "Impacts", "Impacts")>=1 If it's still not working without the typo, do you have an example file? Quote Link to comment Share on other sites More sharing options...
redpaw Posted January 25, 2011 Author Share Posted January 25, 2011 Hmmm, well I am still having a bit of a problem with this, I'm closer, but I still think I'm doing something wrong here. now it registers the dop impact and sets the group for true for all the objects and the sop solver then scales every object at the same time. what I want is for each object to scale as it enters the group, because it registers its own impact. I've attached a simple demo file, if anybody can point me in the right direction that'd be awesome. thanks -johnc sopSolverTest.hipnc Quote Link to comment Share on other sites More sharing options...
