HOT not loading
Hi! I built the HOT source with gcc-4.1.2 (default is 4.5) on my Fedora x64 machine. Everything works fine, except during startup of Houdini the following error message appear:
Houdini DSO - error on '/home/nhatphong.tran/houdini11.0/dso/VEX_Ocean.so'
Compiler incompatibility detected. gcc compiler versions below 4.3 are not compatible with gcc compiler versions 4.3 or above.
I saw something similar in this forum here (http://forums.odforce.net/index.php?/topic/9523-bullet-compiling-issues/page__st__24), but didn't find a solution to this. I'm pretty sure someone has encountered this before. I'd appreciate any help,
Phong
Phong
Problem solved, I installed the latest Houdini for gcc-4.4 package.
Thanks,
Phong
