re-connecting wires
drob78
I'm trying to break a wire after a certain distance apart, but then re-connect once it reaches another distance. So say it breaks at 0.7 it cannot re-connect until the minimum distance of 0 is reached. I tried an if expression but doesn't quite work if the point drops under the "break" point but never reaches the "connect" point. Here is a rough example of what I am trying to do, red would equal it broken and black would be connected. But I it can only turn back to black once it hits the "connect" point.
Cheers
