Smoke question
jlmaradona
HI everyone first of all thank you for read me,my question or dude its the next: is there a way to make a Smoke follow a path and control the behavior of the smoke all inside the container,i need to make a smoke get out of a cup of chocolate pass under a door around a chair a become a logo
thank every one again.
a think a sphere emits inside a container but the smoke i cant control the behaivor
By happy coincidence I was having a look getting volumes to follow a path this morning. I've attached a hip file of where I was at.
The basic set-up is to bring a velocity field into DOPs from SOPs and use a Gas Particle To Field to add the points velocity attribute to the existing velocity field. The main node here is the Gas Particle To Field which allows you to tweak the existing and the added velocity fields.
One of the main drawbacks I've had with this method so far is that the speed of the simulation appears to change when you change the resolution.
The hip file will probably make more sense than my explanation. I hope :) .
Edited by jujoje
