Using camera position to light object.
barad_dur
Hello all,
I am trying to figure out how to put together a surface shader that uses the camera position, relative to an object, to light that object with a falloff-type ramp.
I was thinking that in the shader I would pass a Parameter the camera position and take it into a Dot Product along with a normalized Surface Normal from the Surface Globals but it is apparent now that I am just grasping at straws.
The goal is that no matter how the object is lit with regular scene lights the object that the camera is looking at (maybe I should pass Direction from Eye??) will be lit as if the camera was a light. I could do this by parenting a light to the camera but I'd like to do this at the shader level so I can control the falloff via a ramp parameter.
Any advice would be appreciated. Thank you.
David
