need help on adduservariable()
GB_AttributeRef POP_ContextData::addUserVariable ( const char * name,
int size,
GB_AttribType type,
const void * def,
const char * local = 0
There is no description or example file for this. Can someone give an example?
Thanks!
here's an example
OP_Context &context;
POP_ContextData* data = (POP_ContextData*) context.getData();
float def[4] = {0};
data->addUserVariable( "test", sizeof(float), GB_ATTRIB_FLOAT, def );
this will add a single float (as an attribute) to each particle.
not sure what the last param of local is meant for -- perhaps as a default for strings?
