Guest xionmark Posted May 2, 2011 Share Posted May 2, 2011 Hello, This has got to be an easy one. I need to read the particles coming into the 2nd and 3rd inputs of a POP but I've come up empty. There doesn't seem to be a method to read the data from a specified input like in SOPs. POP_ContextData offers: void getInputGeo (UT_String &path, int index) const void setInputGeo (const UT_String &path, int index) But that's for the SOP geo coming into the POP Network OP. POP_Node has: GU_Detail * getGeo (const char *overridegeopath, const POP_ContextData *data, float t, int addextrainput, int ignorexform, GU_Detail *copygdp, OP_Node **prevsop, int *retdoxform, UT_DMatrix4 *retxform, int *retneedsreset) Which I use successfully to read geo from anywhere in SOPs, but it doesn't seem to have a form to read the particles from another POP node connected to a specified input to a POP. I've tried supplying the input path to getGeo() but Houdini complains. So before calling POP_ContextData::getDetail(), how does one set the input for the data to be sourced from? There's no inputGeo(), duplicateSource(), duplicateChangedSource(), useInputSource(), etc. in a POP_Node class. Surely there's a way to import particles as a separate GU_Detail than the "main gdp" in the POP_ContextData ? Is it right under my nose and it's too obvious? :-) --Mark Quote Link to comment Share on other sites More sharing options...
