kill pop and local varable mapping broken?
HI!
I created an attribute in VOP POP called treshold, and set the variable mapping to TRESHOLD.
After the pop network I put a kill pop, and set the rule $TRESHOLD>3 but local variable mapping seems not to work.
Instead if I append an attribute pop and set
value : $TRESHOLD
this time $TRESHOLD becomes green and all works.
Why kill pop doesn't recognize my local variable mapping as attribute pop does?
The attribute node is special and will map the local variable if it isn't mapped already.
So, the mapping doesn't need to exist for $THRESHOLD to work in the attribute node ...
From what I understand, attribute pop automatically maps incoming attributes, and for this reason I can write $TRESHOLD and see it green.
My question is: if i create an attribute in VOP, and explicitly set the variable mapping, can I use this mapping outside the VOP network? for example in the kill pop, writing $TRESHOLD? or I have to put an attribute pop between the vop and the kill note to create (recreate) the variable mapping for my attributes?
