doc Posted June 8, 2011 Share Posted June 8, 2011 I have a vector value in my volume that I'd like to visualize in the viewport. Is there a direct way to do this? If not, what's the best indirect way of doing this? Quote Link to comment Share on other sites More sharing options...
static Posted June 8, 2011 Share Posted June 8, 2011 Similar to this thread: Create a point in the volume use an attribFromVolume SOP to create a vector attribute on the point In the Display Options (d key when over the viewport), add a custom attribute that is the same name as the attrib created Turn it on to see the vector, or the values in the viewport Quote Link to comment Share on other sites More sharing options...
crin Posted June 8, 2011 Share Posted June 8, 2011 Vector Field Visualization node? If you're in dops. Quote Link to comment Share on other sites More sharing options...
Macha Posted June 8, 2011 Share Posted June 8, 2011 With colors maybe? vecviz.hipnc Quote Link to comment Share on other sites More sharing options...
