HOT shader problem
Hello, Im starting learning more some shading stuff but I have problem in some areas. If I import from displacement min eigenvalue a connect to ramp and all work good but problem starts when I starting to connect spec, refl. Some artefacts appear on the surface. So in color shading works only diffuse which is eigenvalue and some ramps. Where could be problem? Some screens and little testing scene. Thanks a lot for helping. BC...
colour shader graph
HOT displacement
Diffuse with testing foam
Displace, simple reflection with map, some artifacts, but dispacement with reconecting to foam and colour works good
thanks
