Strife Posted June 25, 2011 Share Posted June 25, 2011 Hi, I wanted to do a wave-like motion using a grid. I then copied box on to each points of the grid so what the wave-like movement will do is that it will affect the boxes and make them move in a wave motion. I did a test, however I only manage to achieve only one movement but i wanted a continuous wave-like motion. Can anybody help me out with it? There is a file attached. Thank you. grid_boxes.hipnc Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 25, 2011 Share Posted June 25, 2011 (edited) I did a quick fix using the Ripple SOP. Take a look at my tutorial using it to see one way to do an interference pattern with it, which could do some cool effects with this setup. File looks awesome though, turns out looking amazing. edit: I meant to mention that the null object in the root of the scene controls the center of your ripple, play around with it and see what happens, it does some really cool stuff when you move it around. grid_boxes_FIX.hipnc Edited June 25, 2011 by Adam Ferestad Quote Link to comment Share on other sites More sharing options...
