Find connected primitives
Hi all!
I am trying to write algorithm of finding primitives which connected between each others
and working like combination of the sop nodes connectivity + partition. I've written some code
but it works much slower than combination of nodes (connectivity + partition).
Could you please give me an advice how to make my algorithm faster.
Thanks!
Here is the part of my code:
	//.......cookMySop(OP_Context &context) {
	GEO_Closure closure(*gdp);
	GEO_Primitive* currentPrim=NULL;
	UT_IntArray primlist;
	GB_PointRefArray prefarr(gdp,0);
	int connectivityAttrCounter=1;
	int iteration=0;
	GEO_PrimList primitives = gdp->primitives();
	currentPrim=primitives.head();
	//Go to part of primitives
	while(currentPrim)
		iteration=0;
		//Enter to the recursion function and find neighbor primititves
		int newConnectivity = findConnectivityPrimitives(gdp, closure, currentPrim, h, connectivityAttrCounter, iteration, primitives);
		//if newConnectivity==1 it's means that current part of primitive is define and mark
		if (newConnectivity==1)
			connectivityAttrCounter++;
		//set currentPrim to head of GEO_PrimList primitives
int MyNode::findConnectivityPrimitives( GU_Detail* gdp,
                                        GEO_Closure& closure,
                                        GEO_Primitive* currentPrim,
                                        GEO_AttributeHandle* connectivityAttr,
                                        int& connectivityAttrCounter,
                                        int& iteration,
                                        GEO_PrimList& primitives
	//Set attribute handle
	connectivityAttr->setElement(currentPrim);
	//Check connectivity attribute if it not =0, then cook this prim
	if(!connectivityAttr->getI())
		int primNum = currentPrim->getNum();
		//Set connectivity primitive attribute
		connectivityAttr->setI(connectivityAttrCounter);
		UT_IntArray primitivelist;
		GB_PointRefArray pointrefarr(gdp,0);
		//Go to all Edge and find polys using edge:
		int vrtxs = currentPrim->getVertexCount();
		for(int i=0; i<vrtxs ; i++)
			closure.findPolysUsingEdge( *(currentPrim->getVertex(i).getPt()),
										*(currentPrim->getVertex(i+1).getPt()),
										primitivelist,
										pointrefarr
			//Go to all primitives in primitivelist anf if it's not current fint in it:
			for(int j=0; j<primitivelist.entries() && primitivelist.entries()>1; j++)
				int currentPrimNum = primitivelist(j);
                // Enter to the recursion function and find neighbor primititves
				if (currentPrimNum != primNum)
					findConnectivityPrimitives(gdp, closure, gdp->primitives()(currentPrimNum), connectivityAttr, connectivityAttrCounter, iteration, primitives);
		//remove cooked primitive from GEO_PrimList primitives
		primitives.remove(currentPrim);
		return 1;
	else return 0;
