CtrlLoki Posted July 8, 2011 Share Posted July 8, 2011 Hello, I’m trying to create a series of bullet hole impacts based with pre-fractured geometry using the voronoi sop and using inverted magnet force to push out some select groups produced by the voronoi sop. This all works fine but I have to manually select the groups I want to ‘blow out’ by hand and as I’m doing multiple hits would like to be able to use a group combine to select a range of groups. So far the voronoi fracture sop outputs each piece with a number ie ‘piece_(number)’ but when I use the expression ‘piece_[1-19]’ in the group sop under combine it only seems to group groups 1 and 19 not the whole range. Has anyone else come across this problem or know what I’m doing wrong ? Regards Si. Group_combine.hipnc Quote Link to comment Share on other sites More sharing options...
