Adept Posted July 18, 2011 Share Posted July 18, 2011 Hi, I've been looking into toolbuilding using python and decided to make an usable fluid autoresize tool. It's mainly based on this Old school post (I like this SOP approach more than DOP-based ones around this community) and Resize Fluid tool from the shelf. My script acts as a tool, that's basically what I was after So you create your fluid simulation, click at the shelf button, select fluid container, confirm selection and here you go. Script sets up the object for computing fluid bounds and adds Gas Resize Fluid node to your DOP network. You can merge these bounds with one or more sources or any other additional objects. But to make it work you will have to push the "Update sources" button in the container's interface after any modifications made to source parameters. This is the only way I could update multiparm block inside of the network. Hope this can be convenient for somebody. Add the tool on your shelf: import doptoolutils import adddoputils adddoputils.resizeFluidSops(kwargs) adddoputils.py code: import hou import toolutils import doptoolutils def updateSourcesButton(): import hou resize=hou.node("/obj/fluid_resize_container").evalParm("source_folder") merge_source = hou.node("/obj/fluid_resize_container/merge_source") # Delete multuparm parameters inside of the network and create them again merge_source.setParmExpressions({"numobj": ""}) merge_source.setParmExpressions({"numobj": "ch(\"../source_folder\")"}) # Set references for multiparm parameters for n in range(1,resize+1): merge_source.setParmExpressions({"enable"+str(n): "ch(\"../source_activation"+str(n)+"\")"}) merge_source.parm("objpath"+str(n)).set("`chsop(\"../objpath"+str(n)+"\")`") merge_source.parm("group"+str(n)).set("`chs(\"../group"+str(n)+"\")`") def resizeFluidToMatchSops(fluidnode, matchobject): """ Resizes the fluid dynamic object fluidobject according to match object. """ dopnet = doptoolutils.getCurrentDopNetwork() movenodes = [] fluidtype = doptoolutils.nodeFluidType(fluidnode) solvernode = doptoolutils.nodeFluidSolverNode(fluidnode) merge = doptoolutils.findOrCreateNamedMerge(solvernode, 'post') resize = toolutils.findInputNodeOfType(merge, "gasresizefluid") if resize is None: resize = dopnet.createNode("gasresizefluid", "resizefluid") movenodes.append(resize) merge.setNextInput(resize) # Have resize link to the original smoke object to # make it more straightforward to delete. for channame in [ "tx", "ty", "tz", "sizex", "sizey", "sizez" ]: resize.parm(channame).set(fluidnode.parm(channame)) # Instrument our resize.. if fluidtype.startswith('upres'): fluidtype = fluidtype[len('upres'):] if fluidtype == 'pyro': fluidtype = 'smoke' # Set gasresizefluid parameters resize.parm("fluidtype").set(fluidtype) resize.parm("refobject").set("") resize.parm("reffield").set("") resize.parm("refobjpath").set(matchobject.path()+"/OUT") toolutils.moveNodesToGoodPosition(movenodes) return resize def resizeFluidSops(kwargs): """ Select fluid and set it up to be resizeable. """ sceneviewer = toolutils.activePane(kwargs) if not isinstance(sceneviewer, hou.SceneViewer): raise hou.Error("Invalid pane type for this operation.") # Select the target fluid box. fluidobjects = sceneviewer.selectDynamics( prompt="Select fluid box to resize. Press Enter to complete.", allow_multisel=False) if len(fluidobjects) < 1: raise hou.Error("No fluid container selected to set initial conditions.") fluidobject = fluidobjects[0] fluidnode = doptoolutils.getDopObjectCreator(fluidobject) if fluidnode is None: raise hou.Error("No fluid object node found.") """ Create and configure the reference container for resizing. """ dopnet = doptoolutils.getCurrentDopNetwork() refobject = fluidnode.parent().parent().createNode("geo","fluid_resize_container", run_init_scripts=False) fluidfields = refobject.createNode("dopio","fluidfields") fluidfields.parm("doppath").set(dopnet.path()) fluidfields.setParmExpressions({"defobj": "chs(\""+fluidnode.path()+"/object_name\")"}) fluidfields.parm("fields").set(2) fluidfields.parm("fieldname1").set("density") fluidfields.parm("fieldname2").set("vel") parms = refobject.parmTemplateGroup() parms.hideFolder("Transform", True) parms.hideFolder("Material", True) parms.hideFolder("Render", True) parms.hideFolder("Misc", True) ref_folder = hou.FolderParmTemplate("ref_folder","Resize Container") ref_folder.addParmTemplate(hou.IntParmTemplate("nptsperarea", "Scatter per Area", 1, default_value=([5000]), min=1000, max=20000, help="Scatter points on simulated density to calculate bounds")) ref_folder.addParmTemplate(hou.FloatParmTemplate("treshold", "Density Treshold", 1, default_value=([0]), min=0, max=1, help="Delete density below this value prior to scattering points")) ref_folder.addParmTemplate(hou.SeparatorParmTemplate("sep1")) ref_folder.addParmTemplate(hou.LabelParmTemplate("merge_source", "Merge Sources")) ref_folder.addParmTemplate(hou.ButtonParmTemplate("update", "Update sources", help="Push this to update ObjectMerge node inside", tags={"script_callback": "import adddoputils; adddoputils.updateSourcesButton()", "script_callback_language": "python"})) ref_folder.addParmTemplate(hou.IntParmTemplate("source_activation", "All Sources Activation", 1, default_value=([1]), min=0, max=1, min_is_strict=True, max_is_strict=True, help="Activation of merging all of the listed sources and additional objects")) ref_folder.addParmTemplate(hou.MenuParmTemplate("xformtype", "Transform", "012", ("None", "Into This Object", "Into Specified Object"), 1)) ref_folder.addParmTemplate(hou.StringParmTemplate("xformpath", "Transform object", 1, "", hou.parmNamingScheme.Base1, hou.stringParmType.NodeReference, disable_when=("{ xformtype != 2 }"))) sources_folder=hou.FolderParmTemplate("source_folder","Sources to Merge",folder_type=hou.folderType.MultiparmBlock) sources_folder.addParmTemplate(hou.ToggleParmTemplate("source_activation#", "Source # Activation", default_value=True )) sources_folder.addParmTemplate(hou.StringParmTemplate("objpath#", "Object #", 1, "", hou.parmNamingScheme.Base1,hou.stringParmType.NodeReference)) sources_folder.addParmTemplate(hou.StringParmTemplate("group#", "Group #", 1, "", hou.parmNamingScheme.Base1,hou.stringParmType.Regular)) ref_folder.addParmTemplate(sources_folder) parms.append(ref_folder) refobject.setParmTemplateGroup(parms) keep_density = refobject.createNode("blast","keep_density") keep_density.setFirstInput(fluidfields) keep_density.parm("group").set("@name==vel*") keep_vel = refobject.createNode("blast","keep_vel") keep_vel.setFirstInput(fluidfields) keep_vel.parm("group").set("@name==density") # VOLUME VOP clamping density field below given treshold density_treshold = keep_density.createOutputNode("volumevop","density_treshold") vopglobals = density_treshold.node("volumevopglobal1") treshold = density_treshold.createNode("parameter", "treshold") treshold.parm("parmname").set("treshold") treshold.parm("parmlabel").set("Treshold") compare_density = density_treshold.createNode("compare", "compare_density") compare_density.parm("cmp").set("gte") compare_density.setInput(0, vopglobals, 1) compare_density.setInput(1, treshold, 0) twoway = compare_density.createOutputNode("twoway","switch_density") twoway.setInput(1, vopglobals, 1) vop_output = density_treshold.node("volumevopoutput1") vop_output.setFirstInput(twoway, 0) density_treshold.setParmExpressions({"treshold": "ch(\"../treshold\")"}) # End of VOLUME VOP scatter = refobject.createNode("scatter","scatter") scatter.setFirstInput(density_treshold) scatter.parm("ptsperarea").set(1) scatter.setParmExpressions({"nptsperarea": "ch(\"../nptsperarea\")"}) add_particles = scatter.createOutputNode("add","add_particles") add_particles.parm("addparticlesystem").set(1) # VOP SOP adding velocity field to density-based pointcloud add_vel = refobject.createNode("vopsop","add_vel") add_vel.parm("vex_numthreads").set(1) add_vel.setFirstInput(add_particles) add_vel.setInput(1, keep_vel, 0) globals = add_vel.node("global1") volumesamplex = add_vel.createNode("volumesample", "volumesample_x") volumesamplex.setInput(2, globals, 0) volumesamplex.parm("input_index").set(1) volumesamplex.parm("primnum").set(0) volumesampley = add_vel.createNode("volumesample", "volumesample_y") volumesampley.setInput(2, globals, 0) volumesampley.parm("input_index").set(1) volumesampley.parm("primnum").set(1) volumesamplez = add_vel.createNode("volumesample", "volumesample_z") volumesamplez.setInput(2, globals, 0) volumesamplez.parm("input_index").set(1) volumesamplez.parm("primnum").set(2) vel = volumesamplex.createOutputNode("floattovec", "vel") vel.setInput(1, volumesampley, 0) vel.setInput(2, volumesamplez, 0) vel_by_fps = vel.createOutputNode("divconst", "vel_by_fps") vel_by_fps.setParmExpressions({"divconst": "$FPS"}) add_vector = globals.createOutputNode("add", "add_vector") add_vector.setNextInput(vel_by_fps, 0) vex_output = add_vel.node("output1") vex_output.setFirstInput(add_vector, 0) # End of VOP SOP merge1 = refobject.createNode("merge","merge1") merge1.setFirstInput(add_particles) merge1.setInput(1, add_vel, 0) bound = merge1.createOutputNode("bound", "bound") # Box to switch from after first simulation frame initial_box = refobject.createNode("box", "initial_box") initial_box.setParmExpressions({"sizex": "ch(\""+initial_box.relativePathTo(fluidnode)+"/sizex\")", "sizey": "ch(\""+initial_box.relativePathTo(fluidnode)+"/sizey\")","sizez": "ch(\""+initial_box.relativePathTo(fluidnode)+"/sizez\")"}) initial_box.setParmExpressions({"tx": "ch(\""+initial_box.relativePathTo(fluidnode)+"/tx\")", "ty": "ch(\""+initial_box.relativePathTo(fluidnode)+"/ty\")","tz": "ch(\""+initial_box.relativePathTo(fluidnode)+"/tz\")"}) initial_switch = initial_box.createOutputNode("switch", "initial_switch") initial_switch.setParmExpressions({"input": "$F>ch(\""+initial_switch.relativePathTo(fluidnode)+"/createframe\")", }) initial_switch.setInput(1, bound, 0) # Null to switch to if merging of simulation sources is disabled no_active_source = refobject.createNode("null", "no_active_source") merge_source = refobject.createNode("object_merge", "merge_source") merge_source.setParmExpressions({"numobj": "ch(\"../source_folder\")", "xformtype": "ch(\"../xformtype\")"}) merge_source.parm("xformpath").set("`chsop(\"../xformpath\")`") numobj = merge_source.parm("numobj").eval() source_switch = no_active_source.createOutputNode("switch", "source_switch") source_switch.setParmExpressions({"input": "ch(\"../source_activation\")"}) source_switch.setInput(1, merge_source, 0) merge2 = initial_switch.createOutputNode("merge","merge2") merge2.setInput(1, source_switch, 0) bound = merge2.createOutputNode("bound", "bound") unroll_edges = bound.createOutputNode("ends", "unroll_edges") unroll_edges.parm("closeu").set(4) out = unroll_edges.createOutputNode("null", "OUT") density_treshold.layoutChildren() add_vel.layoutChildren() refobject.layoutChildren() out.setDisplayFlag(True) out.setRenderFlag(True) resize = resizeFluidToMatchSops(fluidnode, refobject) resize.setCurrent(True, True) sceneviewer.enterCurrentNodeState() Quote Link to comment Share on other sites More sharing options...
