restrict angle of rbd anglular constraint
hi,
can I restrict angle of rbd anglular constraint?
I have two pieces of board with hinge(constraint). I key framed one board, then started simulation. But the other board bouncing because of collision.
So I want angle limited (0~180 or 10~170) hinge. How can I achieve that?
Thank you always guys.
Hi, this is what I've done so far.
It doesn't work always. IF THEN, I TURN ON AND OFF THE "NOT_USING" CONSTRAINT. Then it works. Why is it doing like that?
And as you can see, it wasn't accurate enough. So I need some help for raise accuracy. Is there a idea for this?
Can I predict collision and active constraint one frame earlier?
Help me. Thank you!
