Problems with Motion Blur for Particle Fluid Object
kunal
Hi
I am having a problem rendering particle fluids with the correct motion blur. Can anyone see the attached file and tell me what is going wrong here?(weird shaky jitter). I've done a particle fluid sim to create a splash in DOPs, imported the particles in SOPS, added a particle fluid surface node and added velocity in the attribute tab. I have geometry velocity blur checked and rendering with PBR and motion blur.
Am i missing something ? Also any tips on how to make splashes look gorgeous will be highly appreciated
thanks so much for the help
regards
Kunal
Hey Kunal, do you have changing pointcounts? What happens if you preview the velocity vectors, do they jump or jitter? If you render motionblur without geometry velocity blur, does it look correct?
Edited by Macha
