anupamd Posted September 29, 2011 Share Posted September 29, 2011 1. How do I bring in point attributes from SOP level into a shader. (for example, say I have a curvature point attribute that Im trying to use in a shader) in vops i've tried "attribut"e and "import surface variable" but nothing works. "attribute" using cd seems to work in VOPS, but any custom attribute does not. 2. I'm trying to bake out micropolygon displacements out of houdini so that I can generate normals in something like xnormal...etc. is there a good workflow for this, i've read through several threads about this topic and it seems like no one has yet come up with a good pipeline. Seems like this is a super easy thing.. or is it one of those "super easy in other apps, but super hard in houdini" things? Any examples, or links to other topics would be appreciated. 3. On the topic of micropolygon displacements, is there any way to convert mucropolygon displacements into an actual mesh. Im thinking.. some kind of .. point cloud bake the build an SDF volume from that,and then use volumesurfacer to get the polys. Or if there is a simpler way. Anything to get me started in the right direction would be awesome. Thanks! -A Quote Link to comment Share on other sites More sharing options...
sam.h Posted September 29, 2011 Share Posted September 29, 2011 1. How do I bring in point attributes from SOP level into a shader. (for example, say I have a curvature point attribute that Im trying to use in a shader) in vops i've tried "attribut"e and "import surface variable" but nothing works. "attribute" using cd seems to work in VOPS, but any custom attribute does not. use the 'Parameter" node in a shader (also works in SOPs) 2. I'm trying to bake out micropolygon displacements out of houdini so that I can generate normals in something like xnormal...etc. is there a good workflow for this, i've read through several threads about this topic and it seems like no one has yet come up with a good pipeline. Seems like this is a super easy thing.. or is it one of those "super easy in other apps, but super hard in houdini" things? Any examples, or links to other topics would be appreciated. This should be easy if I understand what you want. Do you know how to render in UV space using the "UV object" parameter on the mantra node? Once you have that you can just plug your normals into the Cf output in the shader. you will get your normals. If you happen to have a disp shader it will render those normals. I attached an example. 3. On the topic of micropolygon displacements, is there any way to convert mucropolygon displacements into an actual mesh. Im thinking.. some kind of .. point cloud bake the build an SDF volume from that,and then use volumesurfacer to get the polys. Or if there is a simpler way. Anything to get me started in the right direction would be awesome. Thanks! -A Yup, you can write point clouds from a shader. You would need the normals, then you can use iso offset in point cloud mode to make the mesh. Might work? would be a very heavy mesh though..... renderNormals.hip Quote Link to comment Share on other sites More sharing options...
anupamd Posted September 29, 2011 Author Share Posted September 29, 2011 THANKS for the reply, I will try your rendernormals trick now. But speaking of using pointclouds, why would I need the normal as well in the pointcloud info? How would I utilize the normals in sop space then? -A use the 'Parameter" node in a shader (also works in SOPs) This should be easy if I understand what you want. Do you know how to render in UV space using the "UV object" parameter on the mantra node? Once you have that you can just plug your normals into the Cf output in the shader. you will get your normals. If you happen to have a disp shader it will render those normals. I attached an example. Yup, you can write point clouds from a shader. You would need the normals, then you can use iso offset in point cloud mode to make the mesh. Might work? would be a very heavy mesh though..... Quote Link to comment Share on other sites More sharing options...
sam.h Posted September 30, 2011 Share Posted September 30, 2011 (edited) I think the iso offset node needs normals on the points in pointcloud mode. But this seems like a very roundabout way to do it ... I'm not sure of any other surfacing techniques that would help though ... Edited September 30, 2011 by sam.h Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted September 30, 2011 Share Posted September 30, 2011 (edited) 3. On the topic of micropolygon displacements, is there any way to convert mucropolygon displacements into an actual mesh. Im thinking.. some kind of .. point cloud bake the build an SDF volume from that,and then use volumesurfacer to get the polys. Or if there is a simpler way. Anything to get me started in the right direction would be awesome. If you need the exact micropolygon detail in SOPs I think your mesh would become too heavy especially when generating the surface from the pointcloud. You could however use the pointcloud to transfer the position data to your original mesh (assuming it is reasonably subdivided). I would do the displacement part in SOPs right away using a VOP SOP. See this thread for an example: Procedural Stones/Rock If you want to use a texture instead of a procedural pattern you can use the colormap VOP. -dennis Edited September 30, 2011 by dennis.weil Quote Link to comment Share on other sites More sharing options...
