CVEX_Context question
bareja
Hi I have question about CVEX_Context, I am trying to add some inputs to CVEX_Context and it always says it's equal to 0.
For example:
CVEX_Context        cvex;
cvex.addInput("Npt", CVEX_TYPE_INTEGER, &npts, 1);
load cvex code
CVEX_ValueList &iclist = cvex.getInputList();
std::cout << "inputs: " << iclist.entries() << std::endl;
CVEX_ValueList &oclist = cvex.getOutputList();
std::cout << "outputs: "<< oclist.entries() << std::endl;
and result will be like this:
inputs: 0
outputs: 2
My cvex network is really simple, four parameter nodes, 2 parameter nodes to get and set P and two to get and set Cd.
it looks like getOutputList() works correct, but inputlist should be equal to 3 because one input was defined.
Can you help me and explain what I am doing wrong ?
Cheers!
Edited by bareja
probably I am doing something wrong with code loading, because if I will comment lines responsible for loading, my output is like this:
inputs: 3
outputs: 0
and it make sense, 1 - P, 2 - Cd and 3 - Npt.
Please help :)
P.S.
OK it's working I did mistake with type assignment.
I am sorry,
Thanks.
Edited by bareja
Hey,
I have another question about CVEX_Context, If I will add one input:
// add input
cvex.addInput("P", CVEX_TYPE_VECTOR3, true);
CVEX_Value *P;
GEO_AttributeHandle ahandle = gdp->getPointAttribute("P");
how can I copy/set data from ahandle to *P ? should I copy it ? or maybe somehow I can get pointer to that data and set it to *P ?
thanks
