jim c Posted October 10, 2011 Share Posted October 10, 2011 I'm following along a tutorial from CMI on Fractal and volumes and the guy makes use of a VEX Volume Procedural shader. This appears to be only in H11, is that correct? Is there something I can use in H10 or am I out of luck? Quote Link to comment Share on other sites More sharing options...
old school Posted October 21, 2011 Share Posted October 21, 2011 You can author and render volumes going the i3d route. It is a two step process where you first author the i3d tile-based volume files to disk with a dedicated 3D Texture Generator ROP referencing a dedicated Image3D Texture generator SHOP with VOPs inside it. Once the i3d volume files are authored to disk, you can then reference them with a Mantra i3D Volume Procedural. See the attached hip file. i3d_workflow_file.hip Quote Link to comment Share on other sites More sharing options...
jim c Posted October 26, 2011 Author Share Posted October 26, 2011 Thanks, I just came across this, apologies for not replying sooner! Quote Link to comment Share on other sites More sharing options...
