Secondary shuttering
csp
How can I have secondary individual shuttering on the pieces that have been already shuttered on the first impact with the object?
I hope my question makes some sense, if not I have attached a hip file with an object (plate) who shutters on the air using magnet-force and I want the bigger pieces from the plate to shutter again once they touch the ground. The maximum fractures value is higher than 1 but makes on deference as you can see in the file.
Also, in the file I have iattached the plate self-exploded when touch the metaball which is used by the magnet-force, is there any way to use the same technique to the new bigger pieces that coming out from the first shutter in order to create a fractal destruction?
Any idea or example files will be really appreciated. Thanks in advance.
Christos
selfexplode_test.hipnc
  • 3 weeks later...
