thomwickes Posted November 4, 2011 Share Posted November 4, 2011 I'm attempting to recreate the Newton's cradle example in the gnomon dops dvd. In this, he has a bunch of rbd objects plugged into a merge node, with is then plugged into an apply data node. He then has 2 rbdconstraint nodes plugged into this apply data node. I'm assuming the generic 'rbdconstraint' node has been replaced, but when I try recreating this, I get an error when plugging constraints into the apply data node. The help docs say that it should work but I'm getting a "connection is the wrong type" error. Quote Link to comment Share on other sites More sharing options...
DanBode Posted November 4, 2011 Share Posted November 4, 2011 I haven't seen the DVD you are referring to, but i think you'd need an apply relationship DOP instead of the apply data DOP. Quote Link to comment Share on other sites More sharing options...
