mantra and $HOUDINI_DSO_PATH
doc
two questions:
1) As I remember it houdini uses the $HOUDINI_DSO_PATH to search for DSO's. If $HOUDINI_DSO_PATH
doesn't exit then it uses the $PATH variable. Is this correct?
2) would I be correct in assuming that mantra uses the same search methodology for finding DSO's?
thanks
L
