Referencing files relative to an assets otl location
An OTL can be loaded in different ways, so I'm not sure relative to the OTL will work in Houdini.
If the asset always requires the file, then you should embed the file and use the opdef:/accessname/?filename to access the file.
Otherwise, you should put your files in the Houdini home director, and then use the $HFS to access the file.
