Edit parameters on multiple nodes at once - possible>?
If you select multiple nodes, the parameter editor will show "x nodes selected" and if you change something all of the nodes will be edited.
Or you can use the Parameter Spreadsheet, you can select nodes by typing a pattern and select attributes with a pattern also. You can change parms in there all at once too.
  • 2 weeks later...
