specifying local valuable from outside parameter
Hi everyone,
I got a problem with making one parameter for my digital asset.
I'd like to add one parameter that specifying local valuable from the input to use in the digital assets.
for example, when I type $BBX or $PT on the parameter, it will be passed to inside (lower level) and use that local val to do some process.
I tried but it always shows 0 instead of using the local val I gave...
I attached test hip file.
If someone has any solution, I'm more than happy to hear that.
Thanks!
Hiro
specify_localVal_from_outsideParm.hip
