xtimmyx Posted December 11, 2011 Share Posted December 11, 2011 I just noticed that after frame 6145 the SOP Solver no longer outputs anything. Which conveniently translates to 256 seconds. If I set the simulation up to start outside the frame range 1-6145 the simulation only runs for 1-2 seconds before it goes blank. Running a spinning RBD cube for that range works fine so it definitely seems as though it's related to the SOP Solver. Has anyone run into this and/or has a possible solution to it? I've attached an example scene for you to try with. Just let it run and see if it fails after frame 6145. I'm running Houdini 11.1.67 on OS X. Quote Link to comment Share on other sites More sharing options...
aghourab Posted December 13, 2011 Share Posted December 13, 2011 I just noticed that after frame 6145 the SOP Solver no longer outputs anything. Which conveniently translates to 256 seconds. If I set the simulation up to start outside the frame range 1-6145 the simulation only runs for 1-2 seconds before it goes blank. Running a spinning RBD cube for that range works fine so it definitely seems as though it's related to the SOP Solver. Has anyone run into this and/or has a possible solution to it? I've attached an example scene for you to try with. Just let it run and see if it fails after frame 6145. I'm running Houdini 11.1.67 on OS X. Hmm missing file! Just a silly guess, but you sure its not a memory issue due to caching? Quote Link to comment Share on other sites More sharing options...
