menu subtab python script help needed
strages
dear odforce,
When using the subtab menu under "ordered list" at "edit parameter interface" you get 2 options: manual input, script input.
when putting it in manually it doesnt save my inputs, after resaving that node... veryyyy strange...
however putting it in manually is the only way that i know i can input empty propperties for certain integers. ( i use the list as an integer with chf() ). Can i create a script, with empty unusuable variables so the user cant select certain values.
i hope i am clear.
a normal script would look like this ("token1", "label1", "token2", "label2", ...)
i want it like this sort of: ("token1", "<nothing>", "token2", "label2", ...)
if you do this at manual input you get a line instead of a variable.
plz help is appreciated!
