Nearest Neighbour Point
sadhu
Hello friends,
1) I have scattered points on the grid.
2) Select any random point (startpt group) to begin with, rest of the points will be in availablepts group .
3) Find startpt's nearest neighbour and connect them using add sop.
4) Select this point (nearest neighbour)and find it's nearest neighbour
out of (availablepts - startpt ) group.
and so on till you connect all the points to from a curve.
Please refer the attached file. I think the problem lies in the delet nodes in the foreach sop and availablepts.
Can someone please tell what is the problem with this setup?
Thanks a lot for your time
sop_nearest_neighbour_connect.hipncFetching info...
Edited by sorry
Hi Mike. Thanks a lot for your help. :)
It took me a long time to figure out where I was going wrong. The main part was reusing the available points. Without your help it would have been very difficult for me to figure out the solution.
Attached is the file with the necessary changes in the first post.
sop_nearest_neighbour_connect_done.hipncFetching info...
Edited by sorry
My pleasure :P
