gaurav Posted January 11, 2012 Share Posted January 11, 2012 (edited) Hello Folks, What are some preferred methods of extracting transforms from the sop level and apply them at the scene level ? Something like what rivet does. But how can i access transformation matrix which rivet generates ? I need to transform another obj only for a frame at the obj level as per the orientation of geo inside the sop. Reason being, I dont want to parent my obj to rivet and need it only for a frame to position/orient another obj at scene level. Right now i have very crude way of doing it, Would like to hear how pros do it. Thanks, Edited January 11, 2012 by vectorblur Quote Link to comment Share on other sites More sharing options...
gaurav Posted January 11, 2012 Author Share Posted January 11, 2012 Attaching a hip, just to make it little clear what i am after. Thanks, orient.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Macha Posted January 11, 2012 Share Posted January 11, 2012 If your object is rigid then you can pick a few points and make your own coordinate system out of that and work from there. You may have some luck with oriented bounding boxes too but axes could flip. Could the matchaxis sop do something useful here? Quote Link to comment Share on other sites More sharing options...
sam.h Posted January 12, 2012 Share Posted January 12, 2012 Is there a reason you can't use rivet? Is it because you only want it for one frame? You can use the blend node to mix between transforms ... Quote Link to comment Share on other sites More sharing options...
gaurav Posted January 12, 2012 Author Share Posted January 12, 2012 If your object is rigid then you can pick a few points and make your own coordinate system out of that and work from there. You may have some luck with oriented bounding boxes too but axes could flip. Could the matchaxis sop do something useful here? Hi Macha, Thanks for replying. I too was thinking on the same lines of defining a new coordinate system. Something what rivet does. Also while searing the archives i came across your r&d stuff on AABBs very impressive. I will be looking in it soon once i have the basics in place. step by step. Thanks, Quote Link to comment Share on other sites More sharing options...
gaurav Posted January 12, 2012 Author Share Posted January 12, 2012 Is there a reason you can't use rivet? Is it because you only want it for one frame? You can use the blend node to mix between transforms ... Yes, I wanted to avoid parenting of any sort. So i had to extract transform of rivet explicitly and put them in obj transform at scene level. Cheers, Quote Link to comment Share on other sites More sharing options...
sam.h Posted January 12, 2012 Share Posted January 12, 2012 With python you can use worldTransform() or with hscript expressions you can use origin() to get a transform from an obj. Or in vopsop you can use the lookat node to get a matrix, which you can extract the translation and rotation from, and use a point expression or something on your object nodes. Or you can use the blend node to switch to a rivet transform for just one frame. Quote Link to comment Share on other sites More sharing options...
gaurav Posted January 12, 2012 Author Share Posted January 12, 2012 With python you can use worldTransform() or with hscript expressions you can use origin() to get a transform from an obj. Or in vopsop you can use the lookat node to get a matrix, which you can extract the translation and rotation from, and use a point expression or something on your object nodes. Or you can use the blend node to switch to a rivet transform for just one frame. Hi Sam, Thanks for pro tips. I really liked the origin() and fetch using point(). I also came across to inbuilt extract transform obj. http://www.sidefx.com/docs/houdini11.0/nodes/obj/extractgeo Cheers, Quote Link to comment Share on other sites More sharing options...
eiji Posted April 30, 2014 Share Posted April 30, 2014 Yes, I wanted to avoid parenting of any sort. So i had to extract transform of rivet explicitly and put them in obj transform at scene level. Cheers, I'm very interested how you extract transfrom with VOP. Do you mind sharing your hip file?? thanks Quote Link to comment Share on other sites More sharing options...
beny Posted March 27, 2015 Share Posted March 27, 2015 I'm very interested how you extract transfrom with VOP. Do you mind sharing your hip file?? thanks Bumping up this one as I'm also interested in extracting transform with VOP. I've got it with Python SOP, but the VOP one would be a nice tune-up for my tool Quote Link to comment Share on other sites More sharing options...
gaurav Posted March 27, 2015 Author Share Posted March 27, 2015 (edited) Hey Guys, Sorry been off lately.. I think I used optransform() vex function in inline to fetch transforms of given object and passed returned matrix to extract transform vop. HTH, -GM Edited March 27, 2015 by gaurav Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 28, 2015 Share Posted August 28, 2015 (edited) hello, no big deal but, is there a way to extract the local matrix directly from obj level? Isn't it stored somewhere on the obj? (like maya does) I know I can calculate it, but it would be good to know if there's a more direct method to access it. thanks Edited August 28, 2015 by MENOZ Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted August 28, 2015 Share Posted August 28, 2015 hello, no big deal but, is there a way to extract the local matrix directly from obj level? Isn't it stored somewhere on the obj? (like maya does) I know I can calculate it, but it would be good to know if there's a more direct method to access it. thanks Does this work? http://www.sidefx.com/docs/houdini14.0/hom/hou/ObjNode#localTransform Quote Link to comment Share on other sites More sharing options...
MENOZ Posted August 28, 2015 Share Posted August 28, 2015 (edited) ah, sorry! I forgot to specify I need it in vex Thank you anyway ! Edited August 28, 2015 by MENOZ Quote Link to comment Share on other sites More sharing options...
