Mikal Posted January 30, 2012 Share Posted January 30, 2012 I'm trying to create a shelf tool that manipulates selected SOP geometry in a scene. I would like to be able to directly reference the path of the currently selected node and thought there might be an easy way to do this - like hou.pwd() from a parameter, or kwargs['node'] in a digital asset. Currently the only way I've found of doing this is by cycling through the children of /obj and testing the isSelected() method. Does anyone know if there's a more direct way of accessing selected nodes? Cheers! M Quote Link to comment Share on other sites More sharing options...
graham Posted January 30, 2012 Share Posted January 30, 2012 (edited) Take a look at hou.selectedNodes(): http://www.sidefx.com/docs/houdini11.1/hom/hou/selectedNodes Also, you could use kwargs["pane"] to get the current interface pane and call currentNode() to get something. It's not exactly the same as hou.selectedNodes(), but it's a different way about going at it. Edited January 30, 2012 by graham 1 Quote Link to comment Share on other sites More sharing options...
Mikal Posted February 2, 2012 Author Share Posted February 2, 2012 Thanks graham, exactly what I was after Take a look at hou.selectedNodes(): http://www.sidefx.com/docs/houdini11.1/hom/hou/selectedNodes Also, you could use kwargs["pane"] to get the current interface pane and call currentNode() to get something. It's not exactly the same as hou.selectedNodes(), but it's a different way about going at it. Quote Link to comment Share on other sites More sharing options...
