How to create Metaball influence as Point attribute?
hopbin9
I have a Grid SOP and in the center I've placed a Metaball SOP.
For each point I'd like to have an attribute that represents the field influence of the metaball on the grid. The value range doesn't really matter at this point. It can be clamped 0-1, or start at 0 for the center of the metaball.
I've been going over the manual extensively and can't figure it out. The closest I've gotten is to use the Bulge SOP and then create an attribute using VEX that stores the distance of points between the Bulge SOP and before it. I tried using the Magnet SOP and have it update velocity, color or normals, but it keeps the unit length of those vectors the same. So normals/velocity are rotated but their magnitude remains the same.
It just seems to me this should be a simple thing to do in Houdini.
I'd say just use the Metaball Weight VOP inside a VOP SOP.
oh thanks for sharing that.
op:`opinputpath("..", 1)`
I haven't seen that done before inside VEX. That explains how to use those VEX nodes that reference files. That always had me confused.
