hopbin9 Posted February 9, 2012 Share Posted February 9, 2012 Hi, How are you suppose to create parameters for VOP assets? When I add the parameter VOP node that parameter doesn't appear on the asset's parameters. It's placed way up on the VOP SOP node's parameter list. I want to create VOP assets that have parameters which support being promoted. How do you do that? Right now I use the parameter editor for the asset, but it doesn't feel like that's the right way. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 9, 2012 Author Share Posted February 9, 2012 oh, i figured it out by accident. You create the parameters using the asset editor dialog, and then in the inputs/outputs tab you click "Create/Update Inputs From Parameters" and it makes them inputs and they are promotable. ahh.. I need to go back now and clean up a few assets to work correctly. Quote Link to comment Share on other sites More sharing options...
