strange behavior: volume vop from point cloud
JoshJ
Hey Josh. It's because your radius is set too small, if it can't find a point it seems to use the zero vector and get the distance to that. With your clamp node you get a sphere.
Increase radius, or, if all you want to achieve is turn the curve into a volume, use a volume from att node.
Edited by Macha
