Houdini Fluids to geo
JuriBryan
Hey,
So I was wondering about a effect that I want to create that involves fracturing GEO in a random fashion.
For that I wanted to use a fluid object that that breaks the object apart and then is used to control the direction and velocity of the fractured pieces.
Is there a way to do this the fast way;P
I was wondering if I could use a force with a big negative force that is then controlled by the cached out fluid simulation to break the object apart.
Is that possible or do I need to convert the fluid sim into GEO to break the other object apart?
cheers
