FluidForce
JuriBryan
Hey,
so i am running in one problem after the other while trying out hydro simulations.
Right now I am trying to have my hydro simulation effect a RBD object using the fluidForce node.
But some how the fluidForce always returns a warning that it can't find my fluid object after I specify it.
Any idea why that is or how I could fix that problem.
I don't want to use a normal collision object, because that would not give me the hold back of the fluid but would rather just push the RBD away of the Simulation.
Cheers
Juri
In general you need your units right, feedbackloops set higher than two, and you need to be aware that in a dopnet left affects right, if you merge.
Its a tricky thing to get right though and you're almost certainly better of splitting it into a rbd sim, and a fluid sim.
