goldleaf Posted March 12, 2012 Share Posted March 12, 2012 (edited) I've gone back to a little side project I started back in 2010, creating a Bullet POP to better understand POPs/HDK/Bullet/C++. I've been able to get it working in H12 (spheresA_bulletPOP.mov), but I'm finding the particles' rotations are going nuts (see the attached file particle_rotation.mov), spinning every which way. Visualizing the velocity by putting each component ($VX,$VY,$VZ) into each RGB channel respectively, the velocities seem normal (velocity_rgb.mov). Coloring the particles with the magnitude of the velocity (see velocity_ramp_scrn.png) also shows some erratic behavior (velocity_ramp.mov). Is this because POPs have the orientation, rotation, and velocity all driving the single velocity vector, and in bullet they are separate (and rotation is a quaternion)? Or is there a getRot() function (or something like that, which I haven't been able to find) that I can use to set the rotation of each particle from bullet? My (very rough/unstable) code can be found at: https://github.com/crydalch/houdini-plugins, if you'd like to take a peak. Thanks so much! spheresA_bulletPOP.movFetching info... particle_rotation.movFetching info... velocity_rgb.movFetching info... velocity_ramp.movFetching info... Edited March 12, 2012 by goldleaf Quote Link to comment Share on other sites More sharing options...
