magnet force
sanchoflat
Hm, i change Glue strength and density in box_object, try to change scale force in magnet force, bt the same result. I make my scale force about -10000 but my box just fly in to the sky and dont destroy like in help example.
Y try to add voroniFractureConfigureObject and put - FracturefromMagnetForce on. But result is the same. no destruct reaction. :huh:
Sancho, made the glue strength 0 and the density to 1 and everything works. I think the glue strength is tied to the impacts data, i think the impacts must be higher than the glue strength to break the object.
Try to balance those parameters and the scale of the gravity. Here, I just changed glue strength and the density and, as I said, the box broke.
