FBX FPS EXPORTING
Hello everyone!
I'm, wondering if any of you can help me with a problem I've been having recently. Every time I try to export an FBX from Houdini an occurs that tells me...
"WARNING : UNSUPPORTED FRAME RATE FOUND. DEFAULTING TO 24 FPS."
as well as
"WARNING: COULD NOT EVALUATE A FRAME OF VERTEX CACHE ARRAY. NODE: TIMEBLEND1"
I'm wondering if any of you could help me work around the first error and if any of you could explain the second one in a little more detail.
I AM trying to export at a very high frame rate (384), my question is do any of you know how I can work around it forcing the animation into 24 FPS.
Thank you so much for the help in advance!
