JoshJ Posted April 5, 2012 Share Posted April 5, 2012 In a vop sop, I'd use "import attribute" and choose the input number. how do I access volumes from the extra inputs of a volume vop? the volume in the second input has the same name as the volume connected to input 1, so I think just using the name won't work, and there should be a way to specify the incoming input number. Quote Link to comment Share on other sites More sharing options...
tjeeds Posted April 5, 2012 Share Posted April 5, 2012 I beleive the inputs are mostly there as placeholders, traditionally you access other volumes with a Volume Sample from File node, then you can use op:/full/path/to/node to grab an input index. Parameters only ever work on the primary geometry coming in from the first input. For instance, if you want to get the second input of a volume vop and sample it you would attach a parameter to the file input of the Volume Sample node and set it to op:`opinputpath(".",1)`. Smell what i'm steppin' in? Quote Link to comment Share on other sites More sharing options...
JoshJ Posted April 5, 2012 Author Share Posted April 5, 2012 got it, thanks! Quote Link to comment Share on other sites More sharing options...
jacob clark Posted April 5, 2012 Share Posted April 5, 2012 got it, thanks! Not sure what Houdini build you are on, but I just learned there are now also string parameters at the bottom of the VOP input with pointers to those inputs as well. One less parameter to manage... Quote Link to comment Share on other sites More sharing options...
JoshJ Posted April 6, 2012 Author Share Posted April 6, 2012 Nice! I never noticed those until you just mentioned them. Not sure what Houdini build you are on, but I just learned there are now also string parameters at the bottom of the VOP input with pointers to those inputs as well. One less parameter to manage... Quote Link to comment Share on other sites More sharing options...
