sadhu Posted April 20, 2012 Share Posted April 20, 2012 Hello friends, I am learning vex functions. I came across colormap function. I want to apply color to the grid based on the colormap. Can I use this expression for that? I tried it but it didn't work. 1)I created a custom vex node in material shader builder with outcol output para of color type. 2)In inner code, $outcol = colormap("/obj/cop2net1/Mandril.pic",P,u,v,20) 3) Output of this custom vex node is connected to surface color. But it didn't work. vector colormap(string filename, vector uv, vector du, vector dv, int samples) , I want to use this function. I am not sure what can I input for vector uv, vector du, vector dv. Can someone please help me out with this. Thanks a lot for your time. Quote Link to comment Share on other sites More sharing options...
sadhu Posted April 20, 2012 Author Share Posted April 20, 2012 (edited) It is working. With following changes. 1)I applied uv texture to the grid. 2)Created 3 new inputs, two float para u and v and a vector para uv on custom vex node. 3)Used uvcoords operator and connected its output to u, v and uv of custom vex operator. 4)set ,$outcol = colormap("c:\Program Files\Side Effects Software\Houdini 12.0.575\houdini\pic\Mandril.pic",$uv,$u,$v,100); It is working. Even if I set, $outcol = colormap("c:\Program Files\Side Effects Software\Houdini 12.0.575\houdini\pic\Mandril.pic",$u,$v); It is working. The question is how to use pixel sample input in colormap function in step 4, even if I set it to 0, it is working. Edited April 20, 2012 by sorry Quote Link to comment Share on other sites More sharing options...
