A Object Reflection Issue
Lyonz
Hi all this maybe a simple question but kinda stuck on how to fix it, Other than creating separate materials.
Basically i don't want object reflections in the center of my grid how do you stop this when using the mantra surface shader ? I have attached an example image below:
Note: I can't use the light linker, as this will exclude the whole object from the grid.
PS: I'm using a reflection mask to exclude the center environment reflections. A specular mask to stop light highlights but that doesn't seem to work and also the texture has an alpha.
Cheer Lyonz
