Jan_red Posted May 20, 2012 Share Posted May 20, 2012 (edited) Hello All, Is it possible to set an expression as a default value on a int or float while creating a paramTemplate. At the moment i am trying to set the default value through the default_value argument. Unfortunately this creates an error as it expects an float/int. So far the only way I have found is setting the expression after the ui has been created. Example code: This works fine! But I have to first apply the parm template before being allowed to turn it into an expression. (which i preferbly do not want to do) >>> obj = hou.node('obj') >>> geo = obj.createNode('geo') >>> null = geo.createNode('null') >>> parmTemplateGrp = null.parmTemplateGroup() >>> # here we create our float parm template >>> hou_parm_float = hou.FloatParmTemplate("expressionTest", "works", 1, default_value=([0]), look=hou.parmLook.Regular, naming_scheme=hou.parmNamingScheme.Base1) >>> parmTemplateGrp.append(hou_parm_float) >>> null.setParmTemplateGroup(parmTemplateGrp) >>> myParm = null.parm('expressionTest') >>> myParm.setExpression('$TX') This errors out. As it expects a value. >>> hou_parm_float = hou.FloatParmTemplate("expressionTest", "fails", 1, default_value=(["$TX"]), look=hou.parmLook.Regular, naming_scheme=hou.parmNamingScheme.Base1) Traceback (most recent call last): File "<console>", line 1, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.623/houdini/python2.6libs\hou.py", line 13723, in __init__ this = _hou.new_FloatParmTemplate(*args, **kwargs) TypeError: in method 'new_FloatParmTemplate', argument 4 of type 'std::vector<double,std::allocator<double > > const &' Does anyone have any ideas on how to solve this one ? Thanks! Jan Edited June 20, 2012 by Jan_red Quote Link to comment Share on other sites More sharing options...
Jan_red Posted June 20, 2012 Author Share Posted June 20, 2012 Solved!!(noting it down for future reference) The houdini support has been kind enough to help me out on this one and apparently the documentation was outdated and there is a keyword called default_expression (which totally makes sense) that can be used: # Create a float parameter template with "$F" as the default Hscript expression # for each of the components. parm_template = hou.FloatParmTemplate("my_parm", "My Parm", 3, default_expression=("$F", "$F", "$F"), default_expression_language=(hou.scriptLanguage.Hscript, hou.scriptLanguage.Hscript, hou.scriptLanguage.Hscript)) # Print the default expression and language. print parm_template.defaultExpression() print parm_template.defaultExpressionLanguage() # Set the default expression and language to something else. # Unset the default expression for the 3rd component. parm_template.setDefaultExpression(("$F", "hou.frame()", "")) parm_template.setDefaultExpressionLanguage((hou.scriptLanguage.Hscript, hou.scriptLanguage.Python, hou.scriptLanguage.Hscript)) Quote Link to comment Share on other sites More sharing options...
