oat Posted May 29, 2012 Share Posted May 29, 2012 (sorry for cross posting as I didn't get any advice in Houdini forum) the print command in my python script in a DA may print to Houdini console on one computer and to the Python Shell Panel on another computer... Can we set where the python "print" may print to? Thanks! - Ji Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted May 29, 2012 Share Posted May 29, 2012 (edited) If you set this HOUDINI_WINDOW_CONSOLE = 1 variable in your houdini.env file that you can find in your $HOME directory, it will force Houdini to open floating window for output. EDIT: Hm, it looks that it doesn't force it for Python. Edited May 29, 2012 by mantragora Quote Link to comment Share on other sites More sharing options...
oat Posted May 30, 2012 Author Share Posted May 30, 2012 (seems my previous reply disappeared...) Hi, mantragora, thanks a lot! I found that the output of Print will be directed to the Houdini console if the Python panel is minimized ... Quote Link to comment Share on other sites More sharing options...
