bloomendale Posted May 29, 2012 Share Posted May 29, 2012 Hi. I'm trying to understand POPs after Thinking particles and pflow) And what i hope to find in Houdini is some Value Variance op, especially for vectors. Let's say i want to set velocity of the particles to [0,1,0] with a bit of random deviation of the direction in radians or degrees, where 180 degrees will mean hemisphere distribution. But as far as i cant find built-in solution i use VOP POP, where i mix cross(normalize(initial_vec), normalize (random_vec)) and initial_vec with mix factor from 0 to 1 and then multiply by length (initial_vec). But Mix VOP is using linear interpolation and to make it accurate i have to add a bit more math. Is there more simple solution (possibly built-in)? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Macha Posted May 30, 2012 Share Posted May 30, 2012 What I've done before in this situation is to rotate the vector so that it points along one of the base axes. Then randomly rotate it, and rotate it back with the same amount you used to get it axis aligned. Quote Link to comment Share on other sites More sharing options...
bloomendale Posted May 30, 2012 Author Share Posted May 30, 2012 (edited) What I've done before in this situation is to rotate the vector so that it points along one of the base axes. Then randomly rotate it, and rotate it back with the same amount you used to get it axis aligned. Ended up with this: simple demo attached. 3ak_variance.hip Edited May 30, 2012 by bloomendale Quote Link to comment Share on other sites More sharing options...
gaurav Posted May 30, 2012 Share Posted May 30, 2012 (edited) Is there more simple solution (possibly built-in)? May be mountain sop, also there are various noising vops one could use. EDIT : if it is only initial velocity you want to vary, there is variance parameter in source pop under attributes. Edited May 30, 2012 by vectorblur Quote Link to comment Share on other sites More sharing options...
bloomendale Posted May 30, 2012 Author Share Posted May 30, 2012 (edited) May be mountain sop, also there are various noising vops one could use. EDIT : if it is only initial velocity you want to vary, there is variance parameter in source pop under attributes. Thanks. I used velocity only as example, i know there is variance parameter in Source POP and i'm surprised there is no such one in many other nodes Mountain is using noise, but i'm aiming to do (actually did - a couple posts ago)) is make variance node where i could define vector (let it be velocity) == [0,1,0] and variance == 90, apply it only to newborn particles and get rising reversed cone of particles with 90 deegrees angle in its peak: Oh, and one more question. I discovered that almost every POP operates on the whole bunch of particles. i cannot activate it per particle. And if i want to apply force only on birth i need to group newborns and operate on this group? So POP nodes are performed mostly through groups, not attribs of the particle (and attribs used to group). Am i right? Thanks one more time. Edited May 30, 2012 by bloomendale Quote Link to comment Share on other sites More sharing options...
gaurav Posted May 31, 2012 Share Posted May 31, 2012 (actually did - a couple posts ago)) is make variance node where i could define vector (let it be velocity) == [0,1,0] and variance == 90, apply it only to newborn particles and get rising reversed cone of particles with 90 deegrees angle in its peak: That's Cool. Oh, and one more question. I discovered that almost every POP operates on the whole bunch of particles. i cannot activate it per particle. And if i want to apply force only on birth i need to group newborns and operate on this group? Am i right? AFAIK, Right, one feature of the group pop which was not obvious to me initially, was that one can get particles to group from any where in the simulation, They don't have to be always part of incoming stream. So POP nodes are performed mostly through groups, not attribs of the particle (and attribs used to group). For applying operations on per particle basis based on attribute ,there are local variables to use and i am sure you already know it. Cheers!! Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted June 5, 2012 Share Posted June 5, 2012 I've been looking into doing this with the polar to cartesian vop with good results, I've attached a video below showing it. The bars on the bottom and top are the Phi and Theta ranges for the current frame. https://vimeo.com/43457162 Quote Link to comment Share on other sites More sharing options...
bloomendale Posted June 5, 2012 Author Share Posted June 5, 2012 I've been looking into doing this with the polar to cartesian vop with good results, I've attached a video below showing it. The bars on the bottom and top are the Phi and Theta ranges for the current frame. https://vimeo.com/43457162 Thanks, this will definitely work. will test it. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted June 6, 2012 Share Posted June 6, 2012 Thanks, this will definitely work. will test it. VarianceVop_v004.hipnc Quote Link to comment Share on other sites More sharing options...
