Python Module
resonanz
I have a button and would like to call a function in a Python-Sop. It is not a problem as long as the function is stored in a Python Module under the Scripts tab but how can I call the function if it´s under the Code tab? hou.phm().doSomething() does not work in that case.
Thanks in advance!
You can't call functions from the Code tab. That tab is specifically designed for the cooking of the node. If you need to call code that is in there from somewhere else, move it to the PythonModule.
