twitching fractured cube
JuanDos
I have fractured a basic cube and then have it smash up by doing
1- model > shatter
2- Rigid Bodies > RBD glue
But the cube seems to twitch and the fracture lines are visible(in solid shaded mode) even before it's been hit by another object, is this right or am I doing something wrong. Increasing 'internal Glue' to 100,000 does not solve the issue it just stops it from shattering.
For anyone else interested this is something to do with the voronoi fracture used to break up the object, goto voronoi fracture > cut > cut plane offset and enter something like 0.0001. It's not perfect but makes a big difference. Any more suggestions are welcome otherwise will mark this solved.
