save attribute in DOP
sanchoflat
Solver SOP needs some geometry to work on. You only had the previous frame geometry feeding the display output. At frame 1, the previous frame has no geometry in it. That is the issue you are running in to.
You can use a Switch SOP to switch between the first input and the previous frame with the switch expression $FF>1.
solver_sop_fixed.hipnc
You can create two groups in dops, one with active value = 1 (name - bybullet)with condition - point("/obj/box/null2",$OBJID-1,"activ",0) and other with the active value = 0 (name - bystat) with condition point("/obj/box/null2",$OBJID-1,"activ",0)!= 1.
Make rigid body solver to work only on bybullet group and static solver only onbystat group.
OR
Just create bybullet group, don't use static solver. Make gravity dop work only on bybullet group.
solver_sop_fixed_01.hipnc
