Wire to SBD interaction
chimeric
Hi guys,
I am creating a simulation of a flag. The flag is pinned constrained to the wire. Both of them are affected by a wind force. The cloth obviously follows the behaviour of the wire but the wire ignores the movement of the cloth object. I am using SBD Spring Constraint with Mirror Constraint enable. Plus I have also set Max Feedback Loops to 10, still not result.
Any ideas how to make the mutual affection work?
Thanks,
Dawid
Guest mantragora
I haven't tested wire<=>cloth interaction myself, but I know there is a wire<=>rbd problem. If this is the same problem, check last post link in this topic. It should give you some ideas.
PS. Fajne tornado.
Edited by mantragora
